×I have around 100 closed issues that are in a wrong epic, I need to move them to a different epic.
The bulk edit option is not letting me do that. Any inputs would help please.
Have you thought about using Automation?
Hello @Ganesh Somasundaram
@Prince Nyeche is right you can achieve this with automation, since your on the server you'll need the "Automation for Jira " plugin
Automation steps
This rule needs to be global - Jira Administration -> System -> Automation rules
Since this rule is using a manual trigger you can trigger it from the epic you want to relate to your issues or you can trigger it from any other issue
To manually trigger rule
Open the desired issue/epic -> More -> On the bottom of the drop-down you will find the rule name
To check if it's successful, check rule logs.
BR, Olga
Thanks @Olga Videc
