I want to set which fields should appear based on the selected Issue Type, and don't want to have to set which fields should appear based on which project I'm in. I want the fields for each issue type to be the same across all projects.
I've done the following:
I don't know how to get the fields I created and assigned in steps 1 and 2 above to actually appear for each of my projects when I am creating new issues!!
The key part is that you want to create one ITSS and then configure each project to use that same ITSS.
In that ITSS you have a mapping from the issue type X to a screen scheme usually named "X Screen Scheme". That screen scheme then has a mapping to one, two or three screens for creating, editing and viewing issues of type X.
This is it! I've spent hours searching these forums, even finding the exact same question I have, and this is the key right here. Thank you so much!
My issue now is that JIRA automatically adds a new Issue Type Scheme, new Screens, new Screen Schemes, and new Issue Type Screen Scheme for every new project I create, which defeats the purpose of using one ITSS. Do you know how I can turn that feature off?
When you create a project, select the the Create with Shared Configuration link at the bottom. Not as obvious as it could be I think. But you can't turn it off
Yep, I figured that out. :) Thank you, Matt. You've been most helpful!
When you create custom fields you define which issue types and projects they apply to and can also designate which which screens they appear on. See
https://confluence.atlassian.com/adminjiracloud/configuring-a-custom-field-776636423.html
I don't want to assign fields to projects, I want to assign fields to issue types and that's it. Your link doesn't work by the way.
Now you just need to set that Issue Type Screen Scheme on each of your projects:
Repeat those steps for each project, and you'll get what you need.
Hope it helps.
But then all of my issue types use the same screen! I want to be able to associate fields with a screen, then a screen with an issue type. That's it. Then regardless of what project I'm in, I want all the same fields to appear based on the issue type selection.
I understand this make take some convoluted way to set this up, but what I've typed above is exactly what I want.
Please, have a look at this page:
Besides, the diagram in this other page is quite good for understanding schemes:
Hope it helps.
I've already seen those two pages and they are a bit too convoluted for what I'm trying to accomplish. I run into an issue when I get to the step to configure Issue Type Screen Schemes. Since I can only associate a project with one Issue Type Screen Scheme, how am I supposed to use the same screen for each issue regardless of project, without setting up seperate screen schemes and issue type screen schemes for each of my projects?
