How to create a filter with the linked issues that have links associated with it? for Eg: is blocked by and is cloned by
need this filter to be work in *JIRA CLOUD*
Hello Surfaraz,
Although JQL language does not have a parameter to search for link types on JIRA, the add-on JQL Search Extensions for JIRA Cloud provide you with the parameter linktype that you can use to filter by the links of the issues. For example:
linktype = "is blocked by"
Let us know if this information helps.
HI @Surfaraz T ,
Unfortunately, this is not possible in the Cloud version of Jira. There is a field called "IssueLinkType" available in the later server versions, but it is not searchable in Cloud.
You can send a note to Atlassian to ask them to add this capability here: https://support.atlassian.com/contact/#/
-Scott
That is correct...but as @Petter Gonçalves noted below, there is an add-on that will do it.
-Scott
