How do I delete a project?
Beatriz Aparecida Feliciano December 13, 2018
I have a project, but i don't know delete
3 votes
Deleted user December 13, 2018
Hi @Beatriz Aparecida Feliciano,
If you are a jira administrator then you will be able to delete the projects. Refer to the below Atlassian links which will help you in deleting the project.
Jira server: https://confluence.atlassian.com/adminjiraserver/defining-a-project-938847066.html#Definingaproject-Deleteaproject
  • Choose cog wheel (at the top right menu) > Projects, and select the relevant project.
  • Select Delete project in the Project settings menu.
  • Click Delete to begin deleting the project.
Jira Cloud: https://confluence.atlassian.com/adminjiracloud/creating-editing-deleting-and-hiding-projects-844500729.html
  • Go to your project and click Project settings.
  • Select Delete project from the sidebar.
Sravya
PS Narayanan
March 3, 2020
Cool
Alexey Matveev
December 13, 2018
What Atlassian application do you use? Is it Cloud or Server?
Cloud
I resolved thanks
