I have a project, but i don't know delete
Hi @Beatriz Aparecida Feliciano,
If you are a jira administrator then you will be able to delete the projects. Refer to the below Atlassian links which will help you in deleting the project.
Jira server: https://confluence.atlassian.com/adminjiraserver/defining-a-project-938847066.html#Definingaproject-Deleteaproject
Jira Cloud: https://confluence.atlassian.com/adminjiracloud/creating-editing-deleting-and-hiding-projects-844500729.html
Sravya
Cool
What Atlassian application do you use? Is it Cloud or Server?
