How do I delete uploaded files from my Issues under the "Recent Uploads" section in Jira Software?
marshalyung November 13, 2018
The "Recent Uploads" section is in the popup for file attachment in an Issue. All sources had guided me to Space Tools in Confluence. I couldn't find anything related to deleting files in Jira Software (Cloud). I had already enabled permissions for attachments and deleting attachments.
By the way, this is not related to deleting attachment from Issue. This is specifically on deleting uploaded files shown in "Recent Uploads" of the attachment popup.
Looking forward to viable assistance, thanks in advance!
Andy Heinzer
November 16, 2020
Hi Everyone,
Just wanted to revisit this question, as it is possible to delete these images in Jira Cloud now.  However this particular feature appears to be kept in the new Jira issue view.  If you happened to have turned this off, then you won't have the ability to delete these 'recent uploads'.
To turn on the new issue view:
  1. Click on your avatar found in on the top right corner of the screen
  2. select Personal settings
  3. Scroll down and make sure that this new issue view is enabled
  4. return to the page where you can attach an image (you might have to reload that page for this to work)
I hope this helps.  Once you delete this image, you can turn off the new issue view again if you like.
Andy
Andy Heinzer
November 16, 2020
Just for added context, when you hover over the image with the new issue view on, you can then see a trash icon to delete that image from the recent uploads:
Kathy Dunn
January 19, 2021
I'd like to remove ALL recent uploads, as they go on forever. This feature only allows you to remove one at a time, even if many are selected. A global remove would be ideal.
Zachary Jones
November 15, 2020
This is a pretty important question.  Someone on the team accidentally uploaded an inappropriate image.  How do we remove it?  This is a casual matter.
Andy Heinzer
November 16, 2018
Could you clarify where exactly you see this "Recent Uploads"?   I don't seem to have this same location on my own Jira Cloud site. Maybe grab a screenshot of the page you find this on and post it to this thread to help me understand exactly where you are seeing this.
The closest I have found to the functionality you describe is on a dashboard in Jira.  There you can add a gadget to the dashboard called "Activity Stream".  This stream of activity can display attachments in the feed there.   While this gadget can't currently filter out these specific events, you could remove the gadget entirely from the dashboard as a means to mitigate this if this is indeed the location you are referring to.
marshalyung November 17, 2018
Hi @Andy Heinzer,
Here's a screenshot of "Recent Uploads". You can get this popup with the following steps:
  1. Open an Issue
  2. In the Issue popup, click on the "Add attachment" (paper clip) icon below the issue's title
  3. You'll then see the popup to upload file as shown in the below screenshot
The 3 images in the "Recent Uploads" section are images I've uploaded previously. How do I remove these images? It seems like these images are shown in "Add attachment" popups in all projects. Looking forward to your help soon, thanks!
Andy Heinzer
November 19, 2018
Thanks for explaining this Marshal.   This upload form for Core/Software projects in Jira Cloud currently does not have a means for end users to remove this content.  There is however a feature request for this over in https://jira.atlassian.com/browse/JRACLOUD-68881
I would recommend watching and voting on this issue to help our development team in prioritizing improvements.  Sorry there does not appear to be a better solution for this at the moment, however these recent upload do appear to be limited to the user account that uploaded these.
Like marshalyung likes this
marshalyung November 22, 2018
Thanks for your answer @Andy Heinzer. I'll watch and vote on the issue. Certainly hope it gets resolved soon. In the mean time, I'm glad only the owner of the attachments can see these recently uploaded files.
Control Room Bus
October 4, 2020
Hi, I've got the same problem.
Apparently the feature request is supposed to have been fixed in Jan 2020, but since then people have posted that they can't see any evolution, and neither can I.
Olivier.
