I have downloaded the plug-in 'Checklist' and created 'Definition of Done'. I have managed to add this to only one project; but how do I restrict applying this checklist to only certain issue types. Basically, I want to exclude the issue types - Epic and Story.
Any help/guidance is greatly appreciated.
Thanks!
Hello @Raju Kotha,
You haven't specified precisely which checklist app you use.
In Issue Checklist provided by my team, you can set which issue types get the given checklist: set default checklist for issue type
I hope that helps.
Jack
I am using Checklist for Jira app (https://okapya.atlassian.net/wiki/spaces/CHKCDOC/pages/64058204/Checklist+Definitions).
Thanks!
hi @Raju Kotha,
with Checklist you can't but you might be able to add another validator that checks the issue-types (can't remember whether that's out of the box, I mostly use scriptrunner and that definitely has a validator like that).
let me know if that helps.
