How do I get "Test" to appear in my JIRA Issue Type Menu?
Fon Ngu Sr December 13, 2021
I am working on a sprint using Jira Software and I have the zephyr plugin installed but
I don't see "Test" on my Issue Type menu. What can I do to have Test appear as an option on the Issue type menu? See attached picture. missing test.pngThank you.
Pramodh M
Hi @Fon Ngu Sr
You need to add the Issue type in the Issue type Scheme from the Project is using.
Add the Test Issue type in the Issue type Scheme in Jira Administration UI.
Pramodh
Fon Ngu December 14, 2021
Thanks for your feedback. Could you be more specific?
Could you give me step-by-step instructions?
