Hi there,
We need to consolidate our JIRA cloud instances into one. We have about 6 JIRA projects (and about a dozen confluence spaces) to migrate and don't want to overwrite the target, just add them. One of the JIRA projects references a Confluence space on the same instance - meaning we need to migrate the confluence space as well and have the internal linking update (hopefully).
The destination cloud instance already has both JIRA and Confluence stuff on it.
I don't understand how to access the cloud migration tool or setup a server to do the migrating.
I saw an instruction for importing issues via .CSV but I'm unclear if that includes all the custom schemas we made for the project.
Is there a readme that walks through this process?
Thanks kindly
thanks for the link. They really don't make this easy...I had found the article, but was hoping there was something easier :S
Sorry to be the bearer of bad news. Be thankful that you only need to merge a few projects! We typically get the call when someone needs to merge a lot of data together. That is a lot more messy!
it gives me a 404 error page not found. can you send the link again? and @Emilio Gagliardi_ M_Sc_ did it work for you I am in the process of only consolidating about 40 spaces.
I already did the Projects.
