How do I refer to current issue in SIL
Meer Mansubdar January 3, 2019
I want to roll up effort of current issue. How do I refer the current issue in Simple Issue Language?
Alexey Matveev
January 3, 2019
Here is the guide on how to get values for the current issue:
https://confluence.cprime.io/display/SIL/Variable+resolution
Basically, if you want to get the assignee of the current issue, you would just write:
assignee
That is all. You do not need to provide any other information
Meer Mansubdar January 5, 2019
Thanks @Alexey Matveev that really helped .
Alexey Matveev
January 5, 2019
You are most welcome!
