×Hi, I used Kanban before and it used to have a button in the Board to release. Once released, the tickets that were DONE were removed from the Board. With Next Gen, I don't see the option to release. So I tried adding a Fix Version to each ticket, moved those tickets to DONE, and then released from the Releases menu, but the tickets still remain in the board. How can I make them go away? Thanks.
Hello @Jennifer Greyling
To answer your question: How can I make them go away?
On next-gen Kanban boards, the issues that reach the DONE column will 'disappear' after 2 weeks. This is not configurable at this point in time.
The alternative, to gain a little more control, is to add sprints.
Hi Jennifer - you might refer to this other post for guidance:
There short of is that there is no way to do releases right now on Next-gen boards.
And a little more for your reading :-)
