How do I search for issues based on column colors?
Glenn Weissel October 27, 2017
As a JIRA user I need to search and report on issues based on the 'category colors: To Do, In Progress, Done'  so that when I use the Simplified Software Workflow and add or remove statuses I can see all of the issues assigned to one of the categories.
Peter DeWitt
@Glenn Weissel, the Status colors are actually Status Category.  You can use this JQL to get your issues grouped:
Blue
statusCategory = "To Do"
Yellow
statusCategory = "In Progress"
Green
statusCategory = Done
Glenn Weissel October 30, 2017
Brilliant! Thank you Peter!
