Hello All,
I am Jira system administrator, i am able to see the Re-Index project option in project settings but project admins and Project Lead not able to see that option.
How do i enable Re-Index project option for them?
Thanks in Advance,
Mani
I'm afraid you can not, there's no way to delegate that permission alone.
Thanks @Nic Brough -Adaptavist-
Is there any way that Project admin can Re-Index the project issues?
Thanks in advance,
Mani
Um, see my answer?
I am trying to Re-Index the all issues in a project for every 1 minute with the Script Runner "Escalation services" using below script. However, it is Re-Indexing only particular issue every time. If it is possible to Re-index the all issues every one minute it will solve my problem.
import com.atlassian.jira.issue.index.IssueIndexingService import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.Issue import com.atlassian.jira.util.ImportUtils import org.apache.log4j.Category def issueManager = ComponentAccessor.getIssueManager() def issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService) boolean wasIndexing = ImportUtils.isIndexIssues(); ImportUtils.setIndexIssues(true); log.warn("Reindex issue ${issue.key} ${issue.id}") issueIndexingService.reIndex(issueManager.getIssueObject(issue.id)); ImportUtils.setIndexIssues(wasIndexing);
Thanks in Advance,
Mani
Do NOT do that, it will fail. Please see my response on your duplicate question.
