How does everything work?
aogundimu
March 3, 2022
I want to start using this and I am clueless as to what to do.
2 accepted
Carlos Garcia Navarro
aogundimu
March 3, 2022
Thank you!!
You're welcome! :-)
Marco Mendoza
March 3, 2022
Depends on what you are using it for! But to start check the top tab that says Projects, and then navigate to your line of work! You can also search by the people you know in your company under the People tab uptop as well
