How is it possible to delete an issue in the atlassian cloud?
Admin
August 9, 2018
Although I am admin, I get the following error message when trying to delete an issue:
Sie haben anscheinend versucht, eine Funktion auszuführen, zu deren Ausführung Sie nicht berechtigt sind.
Falls Sie der Ansicht sind, dass diese Meldung falsch ist, Wenden Sie sich bitte an Ihre Jira Administratoren.
What should I do? It seems even as admin I am not allowed to delete an issue.
Joe Pitt
Do not delete issues. When you delete it is GONE. Hardly a week goes by without someone wanting to restore an issue. Deleting issues will come back and bite you when it is the most inconvenient. I suggest closing with a resolution value of Deleted anything you want to delete. I implement a special transition only the project lead can execute and it requires filling in a reason field. Missing issue numbers will eventually cause a question about what it was and why was it deleted even if it was done properly. Missing data always brings in the question of people hiding something that may have looked bad.
The only viable way to restore an issue is to create a new instance of JIRA and restore a backup that has the issues. Then export them to a csv file and import them to your production instance. You will lose the history
Raynard Rhodes
August 9, 2018
I create test tickets and delete them. It doesn't have to necessarily be for a user.
Like barneco likes this
srl295 May 10, 2021
Joe, I'd agree with everything you said, except for the case of spam, which atlassian cloud needs to do more to block.
Admin
August 9, 2018
Thank youi, settign the permissions did help! I had to set them to me personally.
Raynard Rhodes
August 9, 2018
Awesome! Don't forget to upvote the answer for others =]
Raynard Rhodes
August 9, 2018
Thank goodness for google translate.
You will need to ensure that Administrators have the delete issue permission
Project Settings > Permissions
Scroll to Delete Issue to check who has permissions
If you do not have permissions scroll to the top Actions > Edit Permission
Ricardo Hernández Gómez
October 21, 2019
Hi!
I have the same issue, I'm over Jira Cloud Free so I can't edit permissions, but I belongs to administrator group and still can't delete issues. :(
Any advice?
Thanks!
mcleaver33
January 23, 2020
I have the same issue - has anyone figured this out?
agborne
February 22, 2021
same issue here!
Syave Srikanth
use standard trial version or buy a standard plan then u can do it.
Jobin Kuruvilla [Adaptavist]
August 9, 2018
Deleting an issue is controlled by project permissions. Check your project's permission scheme.
See https://confluence.atlassian.com/adminjiracloud/managing-project-permissions-776636362.html for more details.
