Hello community !
Tell me, what's the first thing that comes to your mind when it comes to optimizing Jira?
Thank you :)
Hi Alex,
Many things but the first one is 'Custom fields'
@Fazila Ashraf
Yes, I completely agree!)
Thanks for the answer!
I'll do it)
Maybe something else?)
I want to do as much as possible to help improve its performance.
From the data center performance point of view, i would recommend the resources https://www.atlassian.com/whitepapers/data-center-performance-infographic and https://confluence.atlassian.com/enterprise/jira-data-center-performance-608960753.html. Also https://www.atlassian.com/whitepapers/reducing-overhead-and-improving-jira-performance for Custom fields.
And for a general optimisation view, optimising apps and user licenses makes cost saving :)
Get the governance document properly written and explained to your users
