Is there a way to change projects issue type screen scheme on project create? (With global automation)
Hi @Relja Mihajlović - Rather than changing the scheme on create, I would recommend having a template project with the desired configuration. Then when creating a new project, you can use the option to copy configuration from another project.
Thanks for the comment.
I thought of that first but it looks like that feature is not available on the free plan (if you think of the "Share settings with an existing project").
Ahh yes - I didn't see you were on the Free plan. That is correct.
