How to Check for if an Issue w/ Summary Already Exists in a Project
Vasily Prokhorov October 25, 2019
Our users would like to use a post function to create an issue in a specific project with the condition that an issue with the same summary does not already exist in the target project.
David Fischer
in the conditional execution script, you can use a JQL query to check whether an issue already exists with the same summary:
!jqlSearch("project=PROJ and summary ~ \"${issue.summary}\"",1)
Vasily Prokhorov October 28, 2019
Thanks David!
Would you know how I can write a condition such as:
!!issue.get("SD_Project Name")
AND
!jqlSearch("project=(value of the above field if present) and summary ~ \"${issue.summary}\"",1)
 Thank you for your help ahead of time :) !
David Fischer
Sure:
issue.getAsString("SD_Project Name") &&
!jqlSearch("project=\"${issue.getAsString("SD_Project Name")}\" and summary ~ \"${issue.summary}\"",1)
Like Vasily Prokhorov likes this
Perfect!
Thank you David.
Dionisio Valdes H June 8, 2022
Hi community, this solution or similar may be applicable to Jira automation?
Thanks for your reply
Ollie Guan
