Hi Team,
I want to know that, how to enable the extended project administration permission in the Permission Scheme.
Chandra.
Can someone please answer this question? Yes, I agree that this is example shows the cloud instance. I am in the cloud as well. What is the answer for cloud? As you know, having this permission is imperative to properly administering the project and the board. Therefore, what is the answer for cloud? What specifically do you mean "This is not available to cloud users?" What is not available? The view, the permission or the role? Please provide a clear and detailed answer. Thanks.
Hey @RaeLynn DeParsqual, PMP, CSM, SA ,
The permission Extended project administration is not available in the cloud instance.
This permission allows you to grant a higher level of access to project administrators which allows them to edit non shared workflows by adding existing statues to it and some other features.
Unfortunately, all cloud users can do is give a user the Project Role administrators and this will allow them to edit general project settings but not workflows and request types.
To give a user admin access to the board follow these steps:
To give a user the project role Administrators follow these steps:
I hope this helps! If you are confused about anything I said or need additional clarification, please let me know!
This is helpful, thank you. I do have one more question. Can you please define the difference between jira-administrator, project administrator, administrator and board administrator? If I have missed any administrator roles, that would be helpful as well. Thanks very much.
Hello all,
I would recommend voting for these suggestions if you are looking for extended project administration in Atlassian Cloud: JRACLOUD-70190 & JRACLOUD-62881
Brittany
I think the issue and confusion is because the type of Jira version you are using. As I discovered the other day, this setting is only available to Jira Server and possibly Data Center users. This is not available to cloud users.
@andrew dingfelder from your screenshot, I am guessing you are on cloud. I obviously can't be 100% sure but if the option isn't there, that's probably why.
Go to Projects->Choose your projects. Go to project settings and open the Permissions menu and grant the Extended project permissions:
You can find more info here:
https://confluence.atlassian.com/adminjiraserver/managing-project-permissions-938847145.html
This option is not shown under the Administer Projects setting for my server.
How do you enable this setting?
