How to Migrate a Project from Jira server To Jira Cloud ?
Denis Rodrigues November 4, 2022
Hello friends, could someone give me a tip on how I can migrate a project from Jira server to Jira cloud?
Ex: Migrate entire project with issues, workflow, schemas and etc.
Is there any tool that does this migration?
3 votes
Thiago Manini
November 4, 2022
JCMA lets you migrate a single project. It's the official Atlassian Supported tool for these types of tasks
Denis Rodrigues November 8, 2022
thanks for this tip !
Joe Pitt
There is a plugin to move projects, but I don't know if it works in the cloud. Search in the marketplace.
Diana_Architect_ZigiWave
@Denis Rodrigues hi there! I see @Thiago Manini has pointed you to a solution. I'd simply want to propose another option, in case you decide to try a 3rd party solution (either now, or at some point in the future). Take a look at ZigiOps. It's an integration tool but helps with migrations, also. It will help you migrate projects along with their issues/schemas etc. Feel free to check it out (you can book a meeting to discuss the details).
Regards, Diana (ZigiWave team)
Morning @Diana_Architect_ZigiWave , thanks for the tip, I have another question...
it is possible to migrate only schemes, workflows, screens and etc, separately from projects ?
@Denis Rodrigues sorry for the delay. Unfortunately, our tool cannot help you with that currently. It's something our team plans to develop in the near future.
