Hi @Akshith Kumar ,
Are you looking to clear a field of an issue, mostly the field is only filled / cleared at a transition.
If you want to remove / add values from the list you can choose from, this is done in Administration -> Issues -> Resolutions. (this is instance wide, if you want to change the list per project / issuetype then use workflow transition properties)
Hope this helps!
- Tessa
I want to change this for a particular issue type in a project how to do this in workflow?
Hi @Akshith Kumar ,
you can read about using properties to include or exclude resolutions in the transition here.
Hope this helps!
- Tessa
