When i am trying to create an issue type bug it is throwing the following error. Please find attached screenshot. Eventhough the detected environment is given i am not able to create the issue. Please help
Hi @Akil R As per the screenshot it seems that issue detected environment field is not available on screen but mandatory in field configuration. Kindly contact Jira Admin to make field non mandatory from Field Configuration which is mapped with Bug issue type . If field is not mandatory in Field Configuration then check Workflow validator , might be field is set to Required in workflow validator.
V.Y
Hi @Vikrant Yadav the field is optional in field config. Can you please help me know how to do it in workflow validator please.
It is not. That message is exactly what happens when the field configuration tells Jira the field is mandatory.
I suspect you are looking at the wrong field configuration.
To see the validators that might be doing it, you will need your administrators to edit the workflow for that issue type.
Hi @Nic Brough -Adaptavist- and @Vikrant Yadav . Thanks it was a miss from my end. Its working fine now.
