How to Restrict Create permissions in a project and remaining can view and edit issues
sreekanth_vempala August 15, 2018
please let me know, how to restrict issue create permission and i have four issues types like story
bug
epic
task
only particular user can create the issues in a project and remaining users in a project can view and edit but can't create , plese any one give me the solution
3 votes
Neta Elyakim
August 15, 2018
Go to your project setting -> Permissions -> Actions -> Edit Permissions -> Then edit the "Create Issues" permissions to the relevant user/ group and leave the "Browse Projects" permissions to all your jira users.
Make sure that the Permission Scheme is only for this project and not used in any other projects.
And here is Atlassian docs for it:
https://confluence.atlassian.com/adminjiraserver/managing-project-permissions-938847145.html
Joe Pitt
If you're using the default permission scheme the group that allows users to logon is listed by default.
JIRA works by GRANTING access. You can't restrict access. By default, it grants access to the group used to logon (used to be JIRA-users but may be different on your version).  This is probably where you're getting the access from.
  1. The FIRST thing you need to do to get control is to remove any groups with logon privileges from the permission scheme unless you absolutely want everyone to have that permission.
  2. Then I suggest you setup Project Roles for the various functions like, tester, QA, Browse Only, etc.
  3. One permission scheme will cover almost all projects. The project admin controls project role membership
This may be a big effort, but it will payoff down the road by making it easy to control access.
@Neta Elyakim
Thanks a Lot!!
Neta Elyakim
August 15, 2018
If it's work for you, please accept the answer :)
Neta
srikanth vempala August 15, 2018
@Neta Elyakim
how to accept the answer please let me know
Neta Elyakim
August 15, 2018
Near my first answer, there is check mark like a V
@Neta Elyakim
I can't see that option
Neta Elyakim
August 15, 2018
Oops I'm sorry only the user how to create this question can accept it :)
Ok:)
