How to access issue details using R?
Rajkumar Balakrishnan
I wish to access all issues and issue related details using R. Can someone help me with this?
Nic Brough -Adaptavist-
July 12, 2017
From memory, have a look for RCurl - that enables R to issue http calls and grab the data returned.
With that, R should be able to call JIRA's REST APIs to pull data from JIRA (you'll need to find a JSON library for R as well, that's where my memory fails me)
Thanks Nic for your swift reponse. I tried RCurl with rjson. But, I am nto able to pull custom field info. Can you suggest me a solution for it?
July 12, 2017
Custom fields are returned when you ask for issue data.
Have a look at https://developer.atlassian.com/jiradev/jira-apis/jira-rest-apis/jira-rest-api-tutorials/jira-rest-api-example-query-issues and the documents alongside it.
