How to add Groups to a project role in groovy, script runner console
Carlos David
I'm trying to add (AD) groups to project roles using the Script Runner (5.04) Console, using Jira 7.3.1. I'm trying to use the method:
void addActorsToProjectRole(Collection<String> actors,
                            ProjectRole projectRole,
                            Project project,
                            String actorType,
                            ErrorCollection errorCollection)
source:
https://docs.atlassian.com/jira/7.3.1/com/atlassian/jira/bc/projectroles/ProjectRoleService.html#addActorsToProjectRole-java.util.Collection-com.atlassian.jira.security.roles.ProjectRole-com.atlassian.jira.project.Project-java.lang.String-com.atlassian.jira.util.ErrorCollection-
import com.atlassian.jira.bc.projectroles.ProjectRoleService
import com.atlassian.jira.security.roles.ProjectRole
import com.atlassian.jira.util.SimpleErrorCollection
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.jira.project.ProjectManager
def projectRoleService =ComponentAccessor.getComponent(ProjectRoleService);
def projectRoleManager =ComponentAccessor.getComponent(ProjectRoleManager);
def projectManager =ComponentAccessor.getComponent(ProjectManager);
ProjectRole projectRoleObject = projectRoleManager.getProjectRole("Role Name")
Project project = projectManager.getProjectObjByKey("XYZ")
def errorCollection = new SimpleErrorCollection();
projectRoleService.AddActorsToProjectRole(['Group A'], projectRoleObject, project, "GroupRoleActor.TYPE", errorCollection)
Static type checking errors are the issue. The problem lies with the errorCollection - I am also unable to use:
projectRoleManager.getProjectRoleActors(projectRoleObject, project, errorCollection)
Can anyone help?
2 accepted
Alexey Matveev
November 10, 2017
I changed your code a bit and it was compiled successfuly
import com.atlassian.jira.security.roles.ProjectRoleActor
Collection<String> actorCollection = new ArrayList<>();
actorCollection.add("Group A");
projectRoleService.addActorsToProjectRole(actorCollection, projectRoleObject, project, ProjectRoleActor.USER_ROLE_ACTOR_TYPE, errorCollection)
Carlos David
Thanks also Alexey
Like Vasanthakumar Velusamy likes this
Slava Gefen
Didn't work for me. I used
GROUP_ROLE_ACTOR_TYPE
instead, and it works! 👍
Slava Gefen
BTW @Alexey Matveev Appfire_ can you help with how to add groups into four different roles in the project at the same time?
If I use in the console
four times then only first one executes.
Thanks in advance
With kind regards
Slava
Likhitha Kosanam July 19, 2023
Hi Slava Gefen,
I tried the code its working for me when I tried with
But I need to change the role of  users.
Please suggest
Slava Gefen
Hey @Likhitha Kosanam great that it works for you. To change a role I suppose you need two actions: Remove user from a role and add them to another as described in the doc:
ProjectRoleService (Atlassian JIRA 7.1.2 API)
With kind regards
Slava
Anton Chemlev - Toolstrek -
November 10, 2017
Check this out - https://community.atlassian.com/t5/Product-Apps-questions/Jira-Script-runner-add-user-to-project-role/qaq-p/230748
Below script have no static check errors. Compare your script line by line. And just adapt it to use groups instead of users.
Carlos David
Thanks Anton - I had capitalized the 'a' in addActors by mistake
