How to add comment field mandatory for DONE status without using any add-on
nethra s March 3, 2020
how to add comment field mandatory for DONE status in the transition in jira server. is there any possibility without using any plugin.
Jack Brickey
I have not tried but I believe you can add a Validator to the transition of type field required and chose Comment as the field.
Deleted user March 3, 2020
I don't know if Jira Server is different than Cloud in this regard, but I do use a Validator and a transition screen to require the comment field to be filled out:
Joe Pitt
You can't
can you please recommend the plugin to achieve this task.
Joe Pitt
I use the JIRA suite utilities. It provides several very useful functions Here is a link to make comment required
https://confluence.atlassian.com/jirakb/how-to-configure-comment-field-to-be-required-in-workflow-transition-648381476.html
