How to add role actors in jira using jira java api?
Vedant Kulkarni`
how to add role actor in Jira using java API?
Nic Brough -Adaptavist-
April 30, 2017
Use a ProjectRoleManager to maintain users and groups in a project.
Vedant Kulkarni`
I used the same ProjectRoleManager for adding project role which I added successfully but I don't know how to add groups, users or role actors by using ProjectRoleManager.
April 30, 2017
Create a collection of the ones you want to add and then use projectrolemanager.updateProjectRoleActors.
Vedant Kulkarni`
ok, I will try this.
Thank you.
Kanchan Katkar June 1, 2021
will anyone pls give me an example for ProjectRoleManager or how to getActors?
