I want to add e-mail sender to custom field (email adress). I can add to text to custom field, but I can't add sender variable.
JIRA v7.12.1 & Scriptrunner 5.5.9
My code in incoming mail handler.
// get "TO" from mail
import javax.mail.Message
def addresses = message.getRecipients(Message.RecipientType.TO) as String
// issue create and add attachment
import com.atlassian.jira.config.util.JiraHome
import com.atlassian.jira.service.services.file.FileService
import com.atlassian.jira.service.util.ServiceUtils
import com.atlassian.jira.service.util.handler.MessageUserProcessor
import com.atlassian.jira.user.util.UserManager
import com.atlassian.mail.MailUtils
import org.apache.commons.io.FileUtils
def userManager = ComponentAccessor.getComponent(UserManager)
def projectManager = ComponentAccessor.getProjectManager()
def issueFactory = ComponentAccessor.getIssueFactory()
def messageUserProcessor = ComponentAccessor.getComponent(MessageUserProcessor)
JiraHome jiraHome = ComponentAccessor.getComponent(JiraHome)
def subject = message.getSubject() as String
def issue = ServiceUtils.findIssueObjectInString(subject)
if (issue) {
return
ApplicationUser user = userManager.getUserByName("jiramail")
ApplicationUser reporter = messageUserProcessor.getAuthorFromSender(message) ?: user
def project = projectManager.getProjectObjByKey("TY")
def issueObject = issueFactory.getIssue()
issueObject.setProjectObject(project)
// add "To" info
def TYtest = customFieldManager.getCustomFieldObjectByName("TYtest1")
issueObject.setCustomFieldValue(TYtest, addresses)
// add "To" info
issueObject.setSummary(subject)
issueObject.setDescription(MailUtils.getBody(message))
issueObject.setIssueTypeId(project.issueTypes.find { it.name == "Mail" }.id)
issueObject.setReporter(reporter)
// add sender to custom field
def emailCf = customFieldManager.getCustomFieldObjectByName("E-Mail Adress")
issueObject.setCustomFieldValue(emailCf, reporter)
issue = messageHandlerContext.createIssue(user, issueObject)
def attachments = MailUtils.getAttachments(message)
attachments.each { MailUtils.Attachment attachment ->
def destination = new File(jiraHome.home, FileService.MAIL_DIR).getCanonicalFile()
def file = FileUtils.getFile(destination, attachment.filename) as File
FileUtils.writeByteArrayToFile(file, attachment.contents)
messageHandlerContext.createAttachment(file, attachment.filename, attachment.contentType, user, issue)
What error are you getting ?
What's the type of the E-Mail Address Field ?
Hi David,
Custom field (E-Mail address) is Text Field (single line).
Log 1: Sender isn't a user in jira.
2019-08-16 16:21:01,025 Caesium-1-1 ERROR anonymous teknikbilgi [c.o.scriptrunner.mail.MailHandler] Failed to execute email handler 'teknikbilgi(as provided on first page)' on message with subject 'test16'
com.atlassian.jira.exception.CreateException: com.atlassian.jira.workflow.WorkflowException: Error occurred while creating issue. This could be due to a plugin being incompatible with this version of JIRA. For more details please consult the logs, and see: http://confluence.atlassian.com/x/3McB
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:519)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssueObject(DefaultIssueManager.java:608)
at com.atlassian.jira.issue.managers.RequestCachingIssueManager.createIssueObject(RequestCachingIssueManager.java:209)
at com.atlassian.jira.service.util.handler.DefaultMessageHandlerContext.createIssueWithIssueManager(DefaultMessageHandlerContext.java:248)
at com.atlassian.jira.service.util.handler.DefaultMessageHandlerContext.createIssue(DefaultMessageHandlerContext.java:166)
at com.atlassian.jira.service.services.mail.DelegatingMessageHandlerContext.createIssue(DelegatingMessageHandlerContext.java:43)
at com.atlassian.jira.service.util.handler.MessageHandlerContext$createIssue$0.call(Unknown Source)
at Script119.run(Script119.groovy:53)
Caused by: com.atlassian.jira.workflow.WorkflowException: Error occurred while creating issue. This could be due to a plugin being incompatible with this version of JIRA. For more details please consult the logs, and see: http://confluence.atlassian.com/x/3McB
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:766)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:510)
... 7 more
Caused by: java.lang.ClassCastException: com.atlassian.jira.user.DelegatingApplicationUser cannot be cast to java.lang.String
at com.atlassian.jira.issue.customfields.impl.GenericTextCFType.getDbValueFromObject(GenericTextCFType.java:51)
at com.atlassian.jira.issue.fields.ImmutableCustomField.createValue(ImmutableCustomField.java:693)
at com.atlassian.jira.workflow.function.issue.IssueCreateFunction.execute(IssueCreateFunction.java:81)
at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1014)
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1407)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:606)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:742)
... 8 more
Log 2: Sender is a user in jira.
2019-08-16 16:21:01,618 Caesium-1-1 ERROR anonymous teknikbilgi [c.o.scriptrunner.mail.MailHandler] Failed to execute email handler 'teknikbilgi(as provided on first page)' on message with subject 'test 0816 16'
... 7 more
... 8 more
I believe your problem is located here :
You're trying to cast an object to a string, maybe try to add a .toString()
Thanks David.
I added in code.
"def sender = messageUserProcessor.getAuthorFromSender(message) as String"
Code worked for a user in jira. But code didn't work if sender don't user in jira.
if (issue) {
return
// add "TO" info
// add "TO" info
def emailCf = customFieldManager.getCustomFieldObjectByName("E-Posta Adresiniz")
issueObject.setCustomFieldValue(emailCf, sender)
getAuthorFromSender returns an ApplicationUser object which will be null if not a valid JIRA user.
I would instead use something like
def sender = message.getFrom() as String
that would actually give you the E-Mail Address of the Sender (actually the From: attribute, which is a bit different, but should serve your purpose!)
Let me know if not clear.
Thanks David :) Works.
Only, There are problem for names.
for hotmail : [Nihat Test2 <nihattest2@hotmail.com>]
for gmail : [=?UTF-8?Q?Nihat_=C3=87etinkaya?= <nihat.cetinkaya@gmail.com>]
for company : [=?iso-8859-9?Q?Nihat_=C7etinkaya?= <nihat.cetinkaya@example.com.tr>]
If you need only the email address, you could extract the email by using regex and getting everything between < and > .
This regex would do that : (?<=\<).+?(?=\>)
I'll leave it up to you to find the proper implementation of this in JAVA :)
