×We want to issue deletion to only JIRA admins not for any other Jira users
1. Is there any JIRA global setting to do this ?
2. if no global setting is there any other way to achieve this since we have 400 permission scheme which is difficult to remove user roles from delete permission?
3. or do you have any DB query or script to remove remove user roles from delete permission for 400 permission schemes?
Looking to hear some better solution on this. if any scriptrunner script please share to remove user roles from permission scheme
HI @Dayanand
There isn't a global permission to do this, since issue deletion is project based. Personally, I know no other way of doing this, but manually. But 400 schemes are a lot.
Scriptrunner could be a solution of doing this programmatically https://community.atlassian.com/t5/Jira-questions/Jira-Permission-Scheme-API-using-Script-Runner/qaq-p/1040281
I suggest you should start using the shared schemes while creating tickets. Most of the projects in your system might require a single permission scheme. This will help you in easy maintaining of your Jira systems as well.
It would good if provide me script that remove user roles from delete permission scheme for 400 schemes.
@Dayanand I don't have one unfortunately. But the link I gave you can be a good starting point for you.
I am looking for script or other way to update 300+ permission to removed user roles from revoking delete permission from permission scheme
