How to archive done issues in a project
Gloria Phakathi May 16, 2022
Good day
Please advise is there a way I can archive done issues on Jira Cloud
Mikael Sandberg
Hi @Gloria Phakathi,
You cannot archive individual issues, currently you can only archive projects. If you give a bit more information on what you are trying to accomplish we can give you further advice.
How do I archive the projects?
Mikael Sandberg
Go to Settings > Projects or Projects > View all projects. From here you locate the project and then click on the three-dot menu on the right and select Move to archive.
There is no option to move to archive only move to Trash option
Mikael Sandberg
Project archiving is only available in Premium and Enterprise plans.
Gloria Phakathi May 17, 2022
Thank you does Jira have issue archiving on the paid cloud version?
Mikael Sandberg
No, issue archiving is not a feature in Jira, you only have project archiving if you are on the Premium or Enterprise plans. There is a suggestion to implement issue archiving, but based on the feedback it would most likely never happen, see JRACLOUD-5843 .
FREE
