I am trying to create an automation that when Transitioned from In Review to Approval needed it will auto-assign the ticket to a user based on a custom field called xyz. Field xyz is a single select drop down. If xyz is one of 103, 104, 105 assign to Jeff. If xyz is one of 106, 107, 108 assign to Jessica. If xyz is one of 109, 110, 111 assign to Martha.
Using Automation with the following:
Tigger: Issue Transitioned
Condition: IF or ELSE: Add a condition options
Action: Assing the issue to
E.g:
Hope this helps!
Best regards
Sam
Thank you Sam!! Once I slowed down and looked, I saw what I needed. Thank you for the speedy answer.
Slow down and read the If statement for Else
