×Hi, there
I am trying to make a multi user picker custom field which's default values can be changed when different field values change. That different field can be custom field or components. Is there any way to configure this one ?
Hi @Purevdorj Nyamdorj Welcome to Atlassian community!
yeah you can do this if you have script runner plug-in installed in your jira instance.
If you have script runner plug-in , you need to write a behaviour on custom field that will change user picker default value.
thanks
hi, @Vikrant Yadav
Thank you sir,
if not wrong, script runner plug in is not free right ? is there any other ways to configure this one ?
Purevdorj
Hi @Purevdorj Nyamdorj Yes Scriptrunner is paid plugin and Script Runner behaviour is available for JIRA Server and JIRA DC not for JIRA Cloud.
As per your tags, it seems that you are using JIRA server in JIRA Server you can use one free plugin Automation Lite for JIRA this is a free plugin by Atlassian which you can for fulfil your requirement. Use trigger Issue Transition >> Apply Condition on Issue Fields >> Action Edit issue. It's simple to implement using this plugin.
V.Y
Hi, @Vikrant Yadav
I have created the rule When : issue created, if custom field = A, then edit issue field.
When does this rule works ? automatically
Thank you
I have configured this rule correctly but the rule audit log shows below message.
The following issues did not match the condition:
Whats wrong about this rule ?
Hi, @Vikrant Yadav
I thought second IF statement means checking elseif but this rule was stopping when first IF statement becomes false.
Thank you so much. Is there any ways to recommend you ? :)
Hi @Purevdorj Nyamdorj You can use only one If statement in Automation for JIRA lite version. If/else option is avaialble in PRO version only. If you are using Automation for JIRA lite then you need to create two automation rule. One rule for each If condition.
V.Y
Can I queries from document generator plug in sir ?
Hi @Purevdorj Nyamdorj i am not aware about document generator plugin. You can create new post for this, someone having knowledge about this will help you.
V.Y
I have tried to install Automation for JIRA lite, but an unexpected error occurred message shows. Any idea sir ?
Are you sure you are using JIRA Server not DC version and installing correct plugin version?
If using JIRA Server, Go to Manage Apps >> Search "Automation of JIRA - Server Lite" then click on Install.
