Some of the issues in the project (related to sprint preparation and summary) are the same from sprint to sprint. These issues contain sub-tasks. I would like to add them automatically instead of manually keeping the sub-tasks for each issue as well.
How can this be done?
Hi Karol
The easiest way if you're able to, is to use the REST API via some code (typically javascript, C# or even VBA). Using the API, I create "maintenance" and release tickets (including sub-tasks) each sprint. Alternatively, I believe I've read that there are some add-ons that can help, but I don't know the details of those.
Thank you Warren, As I am not familiar with any programming language I would have to find a different solution.
Does anyone use any plugin for Jira cloud to perform duplicating issues?
