How to block a transition, using a validator, if a field has a specific value without any plugins?
Danilo Simic
Hi everyone, I was wondering if it is possible and how to do this if possible.
In our Jira Cloud instance we have 4 Priority values which are "No Priority Set", "P3", "P2", and "P1".
I am wondering if it is possible to somehow block a transition (specifically the "Create issue" transition) if the value of Priority is "No Priority Set" without using plugins and using a validator.
I am aware that there is a Condition that can do this, but the "Create issue" transition does not have an option to add conditions. Maybe some workaround could be implemented?
Ste Wright
Hi @Danilo Simic
Not that I know of using native functionality.
I'd recommend either...
  1. Create an initial Status Issues go into, which can then have a Condition to get out of, requiring a P1-P3 Priority
  2. Remove the No Priority Set Priority - and set the default Priority to P3, so it's detrimental to not change it to the correct one
  3. Use Automation to manage for this - so if an Issue is created with No Priority Set, it could delete the Issue, or hide it (using an Issue Security Scheme), etc - and let a user know why this happened via Email
Let us know if one of these options works for you!
Ste
Danilo Simic
Thank you for the suggestions. This looks like a great workaround.
I will check if this works for the team.
Like Ste Wright likes this
Nic Brough -Adaptavist-
January 21, 2023
Yes, you can do this natively.
First, remove the "no priority set" option from the priority list.  It does not make sense because it is a priority, so you are setting the priority, but saying you have not.
Second, in the project(s) that need it, make the priority mandatory.
