We have a number of different issue types and would ideally like to be able to see these as different colours on the issue calendar gadget on the dashboard so at a glance you can see the issue types which involve lots of resource in one colour and see how spread out they are. Is this possible on Cloud?
We can not change the colors as it shows it based on priority rather than the issue types.
I'm afraid you can't - the calendar addon uses priority to drive the colours.
If that is the case, then as workaround changing the subtask priority to either moderate or low should not be a problem. such that, all subtasks will be moderate and stories will be of high priority. in this way on calendar one will be able to identify if the due issue type is subtask or story/task. I understand this is not the ideal way but as I mentioned this is a workaround. Let me know your thoughts.
we can restrict for subtasks, but restricting priority for other types of issues does not seem to be a good idea.
