How to clone a project and copy all the issue into new project?
Deleted user September 20, 2018
1. How to clone a project?
2. and copy all the issues from the existing project to the new project?
3. Can i do it without using any add-ons?
thanks,
Tawhid
Ollie Guan
Hi @[deleted],
You can try the following plugin:
  • Clone issues into other projects or issue types.
  • Deep clone attachments, comments or the work log.
  • Deep clone issue links, votes or watchers.
  • Bulk-clone hundreds of issues at once.
  • Use the "create issue" screen to confirm the values or clone an issue immediately.
  • Use presets to reuse commonly used clone actions.
https://marketplace.atlassian.com/apps/1218652/deep-clone-for-jira?hosting=cloud&tab=overview
how I can do it without using any add-ons?
Marlene Kegel - codefortynine
Bulk Clone is a function that Jira doesn't offer at the moment.
But as @Ollie Guan mentioned our cloud app Deep Clone for Jira can help you to quickly Bulk Clone and move up to 1000 issues in one action.
If you have any questions don't hesitate to get in touch with us at support@codefortynine.com.
Update Nov 26, 2020
We've just released an update that enables you to clone entire projects, including settings, components, versions and issues.
Alexey Matveev
September 20, 2018
