Comment cloner un projet, ses plans de tests et les cas de tests liés ?
How to clone a project with its tests plan and tests linked ?
We tried DEEP CLONE but it clones project, test plan but not tests linked to test plan
Hi, Marie-Hélène! Jira does not bundle a feature to clone a project, and neither it has Tests or test plans, and they are likely being provided by a third party app like Xray or Zephyr, this is key because add-on data is usually not stored in Jira itself but in their independent vendor's servers, which means that if another third party add-on is used to duplicate Jira data, it would likely only be able to see the native Jira data, and not any other third party, unless it is established that it has support for data that comes from other specific add-ons. In short it would be necessary to either ask the respective vendors how can you clone the data as well as if it would be possible for their products to work together as well.
