Hi there
There is a software project called abc
I want to create an exact copy of abc project as test _abc project
how can i do
Hi @Aykan Inal ,
Thanks for posting. Are you looking to use marketplace apps for this cloning?
If yes, you can check apps there.
Note - I am not marketplace partner so not recommending directly any names here.
Please let me know if that helps.
no no How can I do this without using a Marketplace product? or what does atlassian jira recommend best practice?
Hello @Aykan Inal ,
Thanks for your quick response.
Please check this previous post discussed here - https://community.atlassian.com/t5/Jira-questions/Clone-Copy-a-Project/qaq-p/1767151.
Hello @Aykan Inal ,
I think I have already mentioned, see my response here and response from Angélica Luz - Atlassian Team.
I don't think there anything on free plan.
hi I clone project for deep clone
but not copy board
how to clone all project (in board) for deep clone ?
Hi @Aykan Inal ,
If you are willing to use, I would suggest check with them directly - https://codefortynine.atlassian.net/servicedesk/customer/portal/1/group/1/create/9 and you can try the demo instance.
