How to configure Test Case with steps in Jira?
Shankar
November 16, 2021
i had added the Issue type as  test case in jira. But if i try to create i can see only summary & description. I want step by step points.
3 votes
Ewa Grabowska-Ptak_SolDevelo_
Hello @Shankar ,
Are you using our QAlity app? It is a Jira app which allows you to easily plan, manage and execute your testing. You can read how to set it up here.
In order to use QAlity, you need to add Jira issue type - QAlity Test. After that you can open any Jira issue task and click on our app icon, then click on +Test Case button to add Test Case and its steps:
Hope it helps! Please feel to contact me in case if you have any question, I will be happy to assist you!
Sagar Gupta June 1, 2023
on execution report you will only get count of test cases but not test steps
Noopur Varshney _AIO Tests_
Hi @Shankar
As pointed above, Jira doesn't have any native functionality to support testing lifecycle. You can give AIO Tests - All-in-One Test Management App for Jira a try.
We are one of the few test management tools that do not treat test entities like cases, executions, cycles, runs, etc. as Jira issues. This approach helps us provide a more seamless and intuitive way of test management.
Key features of the app are
  • easy creation and import of test cases
  • linking to Requirements (Jira stories)
  • organizing in Folders and Sets
  • efficient execution with analytical view of multiple test executions
  • easy recording of run defects and artifacts
  • inbuilt end-to-end traceability and execution reports
  • cross-project support
  • Automation frameworks and integration
  • Dashboards and Gadgets
  • Custom Fields support
  • Testing information from Jira story view
Here is a link to our documentation.
If you would like a demo, please contact us through our support portal or schedule at your convenience from this link.
Noopur
That is correct in our plugin for now, we track the execution statuses of the Test Cases not the Test Steps. Would you like to contact us and discuss your use case with us? You can reach us here. I will note your request for tracking of the Test Steps and forward it to our team.
Best regards,
Ewa
SolDevelo Team
i have administrator rights of QAplus and i want to configure QAplus test cases format
Thank you for contacting us. If you want to add QAlity Test issue types please follow the guide here. Currently, we do not offer any customization to our columns. So, it isn't possible to configure different columns of the Test Cases. We might add such possibility in the future. However, it isn't on our roadmap at the moment.
In case of any questions, I am available at our support channel here.
Best regards,
Ewa
SolDevelo Team
Jarosław Solecki _Deviniti_
Jira natively doesn't have TC's and steps.
You have to install some plugins for Test management like that one
Best regards,
Jarek
what kind of plugin
