I want to save the contents of a multi-issue picker field to another multi-issue picker field since the original field is used as a trigger. It appears that multi-issue fields are not supported in the "Choose Fields to be Set" dropdown. Also, another challenge is if I use the Additional Fields box, there is a comment that says the field must be present on the screen. My secondary, "save" field is not on any screens. Any ideas?
Please note, I am using Jira Data Center, not Jira Cloud.
You may want to refer this article, this should help you setup automation.
Vishal
Hi @Vishal I'll take a look and hopefully it points me in the right direction but that article is for Cloud only, and as I stated, I'm using Jira Data Center. Seems the focus has been to build Automation functionality more for Cloud. Thanks!
