How can I create a dashboard that lets me monitor only specific tickets of a certain project? When I go through the available dashboard widgets I cannot seem to find one that meets this need.
Can anyone help me please?
Regards.
Hi @Ian _I_ - Aware ,
you need to create a filter first that extracts tickets that you want to monitor.
After doing that, you can create a dashboard with Filter Result gadget linked to your filter.
Hope this helps,
Fabio
Thank you for replying @Fabio Racobaldo _Catworkx_
I did think that was the case.
When I try to create the filter I can't find any way on how to filter based on the ticket key. Am I missing something?
Please use the following filter to do that :
issuekey in (EXAMPLE-1, EXAMPLE-2)
where EXAMPLE-1/2 are issue keys.
Hope this helps,
Fabio
