How to create a filter to display its subtask and parent task
Alfred Tan April 15, 2020
How to create a filter to just display the items in Red circle?
Basically they are parent and child.
John Funk
Hi Alfred,
Maybe try something like this:
issuetype in (subTaskIssueTypes()) AND "Parent Link" in (ABC-123)
where ABC-123 is the key of the parent.
Alfred Tan April 16, 2020
Thanks for your reply John.
The parent ticket still not appear in the search window.
John Funk
The parent you list does not appear to be in the list of projects. Is that the case?
Alfred Tan April 19, 2020
Yes. I need the filter can display the parent ad its children.
Thanks in advance.
John Funk
No, my point was that you didn't include the parent in your query. In my example above, replace ABC-123 with your parent key.
Hi John,
I did include the parent.
VNISP1PT-6 is the parent.
John Funk
I would remove the project =  part at the beginning then and rerun it.
Hi John,
Same result after remove the project = part at the beginning.
John Funk
Try Parent Link like in my example.
Like Alfred Tan likes this
