How to create a filter to just display the items in Red circle?
Basically they are parent and child.
Hi Alfred,
Maybe try something like this:
issuetype in (subTaskIssueTypes()) AND "Parent Link" in (ABC-123)
where ABC-123 is the key of the parent.
Thanks for your reply John.
The parent ticket still not appear in the search window.
Yes. I need the filter can display the parent ad its children.
Thanks in advance.
No, my point was that you didn't include the parent in your query. In my example above, replace ABC-123 with your parent key.
Hi John,
Same result after remove the project = part at the beginning.
