I am looking for examples of known useful dashboards and filters that will help visualize Agile team metrics.
What are common metrics that most Agile teams want to be able to review:
And from a project level:
Does anyone have examples of filters to use, or even better, an example of a dashboard that is useful? Thanks.
Hello @Sha Melo , this should help 7 steps to a beautiful and useful agile dashboard
Here are some filters which might help,
- Issues completed in specific sprint
project = projectname AND status in (Resolved, Closed) AND Sprint = sprintno
- Issues missing storypoints
project = projectname AND resolution = Unresolved AND Sprint in openSprints() AND "Story Points" is EMPTY AND type in (Story)
- Active Sprint In Progress Longer than 6 Days
project = projectname AND resolution = Unresolved AND Sprint in openSprints() AND status = "In Progress" AND status changed to "In Progress" before -6d AND issuetype not in (Epic) ORDER BY updatedDate ASC
- Issues in progress and missing due dates
project = projectname AND resolution = Unresolved AND Sprint in openSprints() AND duedate is EMPTY AND Status not in (Open)
- Total number of scheduled issues (based on assignee - pie chart)
- Upcoming or missing duedate
project = projectname AND resolution = Unresolved AND Sprint in openSprints() AND duedate <= 5d
-Future sprint unassigned
project = projectname AND resolution = Unresolved AND Sprint in futureSprints() AND assignee is EMPTY
- All issues open sprint
project = projectname AND Sprint in openSprints()
You can make the adjustments as you like depending upon your requirements, also go see to understand Advanced searching in jira Cloud
Your welcome!
