How to create an automation rule for Issues which should start in order
Leena Pratheepan
Hello all together,
I would like to create a rule to make issues start in order. When one issue is set to Done, the other issue should be in Progress and so on.
Specifically, I am talking about sub-tasks that start one after the other.
How to do this?
With kind regards
Leena
JM Perrot
Hey @Leena Pratheepan
Firstly you can link your sub-tasks when you create them. Else, if you take a directive link (blocks ofr example) you can use it to transition the next subtask when the first one is done?
Else if you have patterns in your subtasks' summary, you can base your rules on it to identify the next one.
Let me know if you have some questions
Regards
JM
Leena Pratheepan
Thanks, @JM Perrot
What you mean with pattern in your subtasks` summary?
Thank you for your Help
Leena Pratheepan
I have done it with scheduled trigger. It works.
JM Perrot
By patern, I mean letters like a suffix or prefix. For example, if you go to development (the subtask might have the prefix "DEV") and then have to go through the quality department (here, you might have QUA for example).
The patern would be something like Prefix-Title-Suffix with predefined components.
With a regular patern you can identify very easly the next task
