How to create an issue using NodeJS and the Jira API - 2022
Adam Pitcher August 12, 2022
Hi All,  I know this is a duplicate topic but the other topics are quite old and I am just about out of my mind on this one.
Am trying to write an AWS Lambda to create a Jira issue at certain points in the year.   Should be pretty simple yes?   No.   I walked through the Jira docs, several blogs and tutorials and nothing is really helping me out here.   I am really hoping someone can just say - HEY STUPID (really I give you permission). Here is what you missed.
My call is as follows
await axios.post(encodeURI(`https://mycompanyurl/rest/api/3/issue`), {
headers: {
'Authorization': `Basic ${Buffer.from(
`myemailaddress:myjiratoken`
).toString('base64')}`,
Accept:'application/json',
'Content-Type':'application/json'
body: bodyData
}).then(res => {
console.log(`statusCode: ${res.status}`);
console.log(`Created = ${res.data.total}`);
total = res.data.total;
}).catch(error => {
console.log(error.response.status)
console.log(error.response.data)
and body Data is (again, super simple - not a lot of moving parts)
let bodyData = `{
"fields": {
"summary": "Test automated ticket",
"project": {
"id": "10058"
And i get back
2022-08-12T23:18:48.305Z 43c72edb-1897-4367-b652-6676593e70b7 INFO 400
2022-08-12T23:18:48.324Z 43c72edb-1897-4367-b652-6676593e70b7 INFO {
errorMessages: [],
errors: { project: 'Specify a valid project ID or key' }
That is my project ID - checked it out in the settings and checked it out in the page source
I am sure, as I said, it is dumb - but I have been going around with this thing all day so may be staring right at it, but am punting to the good people of the Atlassian community.
Thank you all
-Adam
Trudy Claspill
Hello @Adam Pitcher
Is the ID you have provided a valid project ID?
Have you tried submitting the project key instead?
Have you tried submitting the numeric project ID without the surrounding quotes?
Adam Pitcher August 15, 2022
Hi @Trudy Claspill , Thanks for the suggestion but yeah - tried all those.   Just baffling to me.   I am going to go a different way for this one and just have the lambda email an issue and use Jira to convert it.
I will have to figure it out later for an upcoming project, adding subtasks, but will deal with it again then.     It just does not make any sense.
