How to create custom fields for Projects?
Pav Kryv
July 5, 2019
Is it possible?
Currenly Jira projects have fields such as:
Project,Key, Project type, Project lead, Project category and URL
Can I add more?
Nic Brough -Adaptavist-
July 6, 2019
You can't do this off-the-shelf.  There are no "project custom fields" built into it.
There is a nifty little app called Profields that provides this sort of functionality.
Guillermo _DEISER_
Thank you @Nic Brough -Adaptavist- for the mention, Yes you can do a lot of thing related with Project Level fields and even with Projects using Profields @Pav Kryv
You can try it and contact with us if you have any additional questions. The support team will be pleased to help you.
Cheers
Pav Kryv
July 6, 2019
Thank you guys. I'll try it on Monday!
Brant Schroeder
Jira allows you to add custom fields.  You can learn more here:  https://confluence.atlassian.com/adminjiraserver/adding-a-custom-field-938847222.html  Custom fields can be added and associated with all projects or a single project.  https://confluence.atlassian.com/adminjiraserver/custom-fields-with-global-contexts-956713282.html
