How to create issues automatically with a specific issuetype in all Projects?
Rinjini Poddar September 16, 2022
The conditions are:-
1. Create issues automatically in all Projects
2. It should not be editable by anyone
Can anyone give me a solution for this?
ChristopherChilds
Are you asking to create an Issue and then that same issue is created in all projects automatically?
I think you will need to look into Project Automation. There is a paid version and a Free version.
Is there any other solution for this?
ChristopherChilds
You could also do this with Script runner but it is a paid plugin. Will involve some groovy scripting.
Thank you
