How does one create subtasks with the jira-python library ?
The trick is that parent id is not the issue id, but the issue key and subtype has to be 'Sub-task'
For example:
rootnn_dict = { 'project' : { 'key': 'JBIDE' }, 'summary' : 'Test auto created issue', 'description' : 'Ignore this. will be deleted shortly', 'issuetype' : { 'name' : 'Task' }, } rootnn = jira.create_issue(fields=rootnn_dict) print("created " + rootnn.key) rootnn_dict = { 'project' : { 'key': 'JBIDE' }, 'summary' : 'Test child auto created issue', 'description' : 'Ignore this child. will be deleted shortly', 'issuetype' : { 'name' : 'Sub-task' }, 'parent' : { 'id' : rootnn.key}, } child = jira.create_issue(fields=rootnn_dict) print("created child: " + child.key)
Still i am getting error with include all of these... the error is that the issue type and id is not
when i am creating a sub-task this is the error actually encountered me..
""Could not find issue by id or key.""
this is the main error i am getting please resolve it immediately pls waiting for it,... help me somebody.
Please replace
with
'parent' : { 'key' : rootnn.key},
See https://answers.atlassian.com/questions/49433/creating-sub-task-of-an-issue-using-rest-api for the fields to set and then use the regular create_issue() function.
I figured it out. Had a bad delete that was failing covering up the error. i'll post answer.
I tried this in many various combinations but no luck.
rootnn_dict = {
'summary' : 'Test chfild auto created issue',
'description' : 'Igfnore this child. will be deleted shortly',
'issuetype' : { 'id' : '5' },
'parent' : { "id" : rootnn.key},
But the last child creation fails.
when i am giving issue type as 5 it is saying that give the proper issue type..please help me.
