How to customize issue navigator columns?
Omkar Rajale
I have two custom fields with the same name "Story points", In the issue navigator when i try to add story points column, only one field is available. But the column populates values of both fields in the same column.
John Funk
Hi Omkar,
This is probably due to using Team-managed projects when the same name exists for multiple custom fields since the projects are all independent. If you go to Settings > Issues > Custom fields, can you verify if you see 1, 2 or no fields by that name?
Omkar Rajale
Hi John ,
In Custom fields I see two fields with the same name.
Like John Funk likes this
John Funk
There's your problem then. Someone has created another field with the exact same name. You should change the name of the one that was not the original one added by Atlassian.
Like Omkar Rajale likes this
Omkar Rajale
John Funk
You are welcome.
